Ford N9
Rob Heynen
10-29-2001 10:45:01
Upon bypassing the Ammeter and putting the two wires in question from the block to the generator cut-out, the tractor still would not start. There was, however, a third wire coming from the Ammeter going to the ignition switch. I disconnected that wire from the Ammeter and spliced it into the same line from the block to the cut-out. The tractor started right up. It seems the Ammeter was the culprit. I would like to thank Dan, Ed, and Claus for their responses to my problem. Because of their suggestions on how to pin down the problem, I was successful.
Ed-Illinois
10-29-2001 11:20:25
 Re: Ford N9 in reply to Rob Heynen, 10-29-2001 10:45:01
you are welcome, and good to hear she is running.
I am curious as to why an ammeter has three wires
by the way, I have a voodoo doll that I put a pin in every time I find some other way that a previous owner butchered my '46 2N's electrical system.
