How to attach badges with hood on?
BERT
11-28-2001 06:30:58
Putting the final touches on my 2N renovation. Got a great looking Ferguson badge from DonB. Got my wife to repaint my original Ford 2N oval.
Now I realize there is no easy way to attach these with the hood on. I cant get my arm inside the grill to push on the speed clip.
Anybody know how this could be done (short of removing the hood)
I suppose some type of adhesive could work, but I would always worry about it shaking loose. Someone recommended tough-as-nails or some such goop.
Any ideas would be appreciated, the parade is Saturday.
gillman
11-28-2001 13:55:12
 Re: How to attach badges with hood on? in reply to BERT, 11-28-2001 06:30:58
only two bolts at bottom of grill and grill slides down and out thru bottom. grill is not bolted at top/only two retaining pins that slip in/out of hood.you might have to loosen the dogleg bolts just a little if the grill is in between them tight. 10/15 min. job.
Phil (VA)
11-28-2001 10:31:24
Get a Ferguson, and you can just raise the hood. (Don't hit me; just kidding. But it's true.)
Eddie S.
11-28-2001 09:35:39
If you remove the two bottom bolts on the "dog-legs", you can easily remove the grille. The clearence between the hood and the radiator is about 2.5 inches. --More than enough room.
Hope this helps!
Eddie S.
Barnstormer
11-28-2001 08:07:03
You might try just removing the 2 bottom bolts of the hood and just remove the grill. I haven't done that so i'm not sure about the clearence to the radiator. Good luck and enjoy the parade.
Claus
11-28-2001 07:38:04
It only takes me about 15 minutes to remove my hood. That is without help. With help probably about 10 minutes.... I would suggest that route, unless you have a trained cockroach who could do it for you...
Happy Motoring
Claus
Larry,Mo
11-28-2001 10:33:09
 Re: Re: How to attach badges with hood on? in reply to Claus, 11-28-2001 07:38:04
If one person tries to lift the hood, is there a best location to stand for leverage and less damage to the back, such as standing in front and reaching around? I need to take mine off but can't seem to match the time when help is available. Thanks
Barnstormer
11-28-2001 11:47:45
 Re: Re: Re: How to attach badges with hood on? in reply to Larry,Mo, 11-28-2001 10:33:09
This should give everyone a chuckle. I needed help to get the hood off of an 8N. The only help available was my better half and she is not very big or strong. I threw a rope over a beam in the barn and tied one end to the hood at an estimated balance point. The other end had a loop around my wife's backside. I lifted and she backed-up, nice and easy.
Claus
11-28-2001 10:41:17
I stand in front...If at all possible, get help... Make sure the gas tank is empty.. It is also easier if you remove the steering wheel...
Happy Motoring
Claus
Larry,Mo
11-28-2001 11:14:51
 Re: Re: Re: Re: How to attach badges with hood on? in reply to Claus, 11-28-2001 10:41:17
Thanks for the comments.
