Order Ford 9N Parts Online
9N AND 2N ARE THE SAME?
BOB(PA)
01-01-2002 08:59:14
have a 9n,puttin new rear gears,boy they are really torn up (teeth missing)
1-9n and 2n same gears?
2-anything to look for inside case when in there,(stress cracks)?
3-hyd. pump works good just going to clean gunk out of bottom of case.replace anything on pump while it is out?
4-all help is gladly taken THANKS BOB(PA)
THANKS EVERY ONE!
01-01-2002 15:05:24
 Re: 9N AND 2N ARE THE SAME? in reply to BOB(PA), 01-01-2002 08:59:14
Scott
01-01-2002 10:50:29
Just make sure the parts came from the same tractor, They need to be matched. Ford had 2 different ones, Standard and H.D., Some could have more wear on one compared to the other.
Truck
01-01-2002 10:35:15
As long as you're in there pull that pump and clean it up good. replace any gaskets, and a new releif valve wouldn't be a bad idea. While you are in the back of the tractor, throw the NAA Hydraulic piston in there, and an O ring. Hey, as long as you're at it, time to redo the brakes, and put in a sure seal setup too. And if you are seeing leakage from the lower lift arms pivots, fix it NOW! I haven't fixed mine yet but it is on the list for sure.It'd be agreaat time to clean up the outsides of all teh castings with a wire wheel(Wear eye protection!!!!!)and get a coat of paint back there.While you're cleaning out resevoirs, flush out that tranny!(You know the oil is mixed between all three, tranny, hyd, and rear?) Can you see why I haven't actually finished an N yet? Thank God they are simple!
Rusty 2N
01-01-2002 09:06:18
I found a crack where the front pinion bearing rides. Thats why I had to change the rear housing. Good luck& play safe.
