Multimeter
BC Mike C
11-26-2002 19:45:19
Was embarrased to confuse the group with the readings from my old multimeter which would not measure volts correctly and would not read one or two ohms. So with a ballast resistor in hand I went to the auto electric shop and said " please meassure this for me " was 2 ohms. Of to the stores I went and asked them to please demonstrate their new meters for me. Quite a few of them, digital and needle type would not give me a two ohm reading. Finally found a nice unit in my price range that past the test. Took it home and finally was able to test everything. Found I had 7 ohms resistance from a corroded connection on the trip from the ignition to the coil. Purchased a bunch of ignition pieces also today, now I have an International tractor. Parts are from Mexico, Taiwan or a place called Original controlled quality. Some parts are even made in the USA. BC Mike C providing your Canadian content.
Dell (WA)
11-27-2002 08:49:40
 Re: Multimeter in reply to BC Mike C, 11-26-2002 19:45:19
Mike..... ...good and smart lesson there. Accurate low ohm meter reading is always a technical challenge. In a cal lab they use a Wheatstone Bridge and a Galvinometer. When asked which is more accurate, Digital or Analog meter? I always say ya makes fewer mistakes reading a digital meter.
Technically, in the A to D converter, there is always the unknowable last value digit step. But now adays, with 12 bit A/D so cheap and commonally available, last bit value become moot. Precision digital meters$$$ use 15 bit A/D's, but they still don't know what that last bit value is, except they know more accurately.
Remember the 6 volt mantra: "Keep'em clean, bright, and tight" still applies to 12 volt circuts too..... .....Dell
Phil (NJ-AZ-SK)
11-27-2002 11:11:52
 Re: Re: Multimeter in reply to Dell (WA), 11-27-2002 08:49:40
Dell, All analog meters function as Wheatstone Bridge's.
JMHO
Tom A
11-27-2002 02:08:59
Thanks Mike.
You know, I had an old VOM since I was a kid, a Radio Shack that probably cost my dad $5. Last year I dropped (for about the 100th time) onto concrete, this time from a ladder and it broke. After a proper burial, I bought a fancy-dancy digital...couldn't get a good reading to save my life. So I went to radio shack, bought their cheapest needle VOM (think it was about a dozen bucks nowadays) and I'm back in business. Not sure if it is lack of QC with the meters or just me and you can't teach an old dog, but it was sort of disappointing about the digital. Now with your story, I can at least claim it is the meter and not me!
thanks,
Tom
Phil (NJ-AZ-SK)
11-27-2002 07:11:21
 Re: Re: Multimeter in reply to Tom A, 11-27-2002 02:08:59
Tom A, Digital meters work wonderfully on "pure" DC or Ohms. The general rule is that a shifting/varying voltage will confuse the meters sampling rate. I have two Flukes and the 8060A, which is the most expensive/acurate (~$500.), is less acurate when used on analog circuits.
The old (El-cheapo)Analog meter works the best on simple or complicated analog circuits.
JMHO
