I should have thought this through
BC Mike C
12-13-2002 20:15:19
Thought I might finally check the compression. My guage is the push the rubber grommet tight into the hole model, but there is not enough room to do this so I took of the end fitting and attatched a flexible hose that screws it to the plug whole. Screwed it in oppened the throttle and cranked the engine and the meter read 92 lbs for a nano second then zero then 92 then zero and so on. The rubber grommett and its fitting has the valve in it that keeps the air from leaking out of the dial unit. BC Mike C
mark ct
12-13-2002 21:13:06
 Re: I should have thought this through in reply to BC Mike C , 12-13-2002 20:15:19
sunds like ya have the litle valve in th gauge not holdin the presure that it shold. the gaugee shouldnt go downtil ya relese the presure by pushin down the litttl buton on the shrader valve
BC Mike C
12-14-2002 07:11:15
 Re: Re: I should have thought this through in reply to mark ct, 12-13-2002 21:13:06
Mark ct thats where I screwed up, I removed the pressure valve. There is no place for it with the flexible hose connected. Now I will go and study other units, I may need a new guage. BC Mike C
Maybe.......bg
12-13-2002 20:20:56
...if you had a gear-reduction starter, it would work better? ;^)
BC Mike C
12-13-2002 20:29:06
 Re: Re: I should have thought this through in reply to Maybe.......bg, 12-13-2002 20:20:56
bg I got the sheet metal shop started on building a trough for the back of the spreader. Hoping it will save me a lot of time next spring puting the manure on the bleuberries. BC Mike C
