GAPPING SPARK PLUGS
BIGDOG
06-01-2000 06:23:35
I GUESS I HAVE ALWAYS ASSUMED THAT WHEN YOU BOUGHT SPARK PLUGS THEY CAME CORRECTLY GAPPED. I HAVE BEEN USING H-10 AND H-12 CHAMPION PLUGS FOR YEARS.
YESTERDAY I PUT IN AUTOLITE 437 PLUGS , BUT BEFORE I DID I CHECKED THE GAP AND FOUND IT TO BE AROUND 35/1000'S. KNOWING THAT THE GAP SHOULD BE 25/1000'S I REGAPPED THEM AND INSTALLED THEM. DID I DO THE RIGHT THING. THE OLD 2N RAN LIKE A CHAMP LAST NIGHT WHILE MOWING, BUT I WOULD LIKE TO KNOW FOR THE NEXT TIME IF REGAPPING IS ALWAYS NECESSARY?
dale b
06-02-2000 07:32:54
 Re: GAPPING SPARK PLUGS in reply to BIGDOG, 06-01-2000 06:23:35
big dog, ALWAYS, ALWAYS gap any plug before installing. it takes almost no time and will give you the best results. have fun, dale b ontario canada
Bruce in 100 Mile House
06-01-2000 19:45:00
You should always regap all the plugs as they may be bumped or dropped.I had an mishap years ago when someone put a set of plugs in that came right out of the box.The engine had a bad miss and the scope showed a bad plug.When i pulled it out i found that it had been dropped at some point ond there was no gap on the plug.Now they pack the plugs with a protective sleeve on the threads to help stop that from happening.
Brian in S. IL
06-01-2000 07:25:30
Yep, it's ALWAYS necessary to regap the spark plugs to the recommended gap for optimum engine performance.
