GOVENOR
BOB2N
06-19-2000 18:24:57
MY TRACTOR DOES NOT SEEM TO RESPOND WITH THE GOVENOR I MOWED TODAY AND IT BOGGED DOWN IN HEAVY GRASS OM USING A WOODS MOWER RD6000 ,IT WILL CHANGE ENGINE SPEED IF U MANUALLY MOVE THE ROD, COULD THE GOV BE STUCK OR DOES IT NOT PICK THE ENGINE UP IN THIS APPLICATION THANKS IN ADVANCE GUYS
Dave Todd
06-20-2000 18:12:26
 Re: GOVENOR in reply to BOB2N, 06-19-2000 18:24:57
Bob, Sounds like you need some work on your Govy. It should maintain a constant RPM or very close, regardless of what is hooked to the tractor. I know some parts are available, and they are not that difficult to figure out. Just be careful when you put it back on the engine, to make sure it fits correctly before you tighten it down. My experience has been a tight fit in the hole where it mounts up, and you could get it cocked a little if not careful. If you don't have one, the I&T manual has a nice section on govenor repair, with some exploded views. Sorry I couldn't be of more help, but they can be fixed. Good luck!!
Dave
