Order Ford 8N Parts Online
8N rear end
Rob S
06-24-2000 14:56:28
I'm looking at a 1949 8N (s/n 245548) and the other markings match with info on the engine block (front distributor, no proof meter, etc). The only question is that the left rear axle housing is stamped with 2N 4015 az and 11-2-47. Am I safe to assume that part of the rear-end has been swapped-out at one time, or were any manufactured as such. Thanks
D. R. White
06-24-2000 18:03:39
 Re: 8N rear end in reply to Rob S, 06-24-2000 14:56:28
Rob, The first 8 "N"s where rolling off the line at ford in July of 1947. I'am not sure why the "2"N shows up on the casting number but the housing casting number on the 2Ns where 2N-4012-A2 for the R.H. and 2N-4013-A2 for the L.H. side. Also keep in mind that some parts where made well in advance and the firt in firt out inventory control was probably not important then. Dave
