Carb Question, and Serial Number
Rob W.
07-24-2000 16:57:33
I put a new exhaust on the 8n, and fixed the air cleaner hose to get things in order. I still have a strong smell of gas when I run the tractor, and I have the main jet turned out only 1 turn as per the original owners manual states that came with the tractor. How do tell what kind of carb is on the tractor. I am spoiled by a tractor shop that stocks parts, only 5 minutes from work. They have carb kits for a few different carbs.
Where is the serial number located, I looked along both sides and can't find it. It is a side distributor model so I know it has to be 50-52.
When I put it into gear sometimes it will kill in 3, 4, or reverse. Rob
norm-wy
07-24-2000 21:15:13
 Re: Carb Question, and Serial Number in reply to Rob W., 07-24-2000 16:57:33
Rob
The carb (if original) on 8N's prior to ser # 276115 should be a Marvel Schwebler TSX241, and ones between 276115 and 313112 are Marvel Schwebler TSX241A. Those from 313112 on up are Marvel Schwebler TSX 241B FWIW
STUMP PULLER
07-24-2000 18:18:00
YOU CAN FIND THE SN JUST BELOW THE HEAD ON THE STARTER SIDE OF THE ENGINE. ONE TURN IS FOR STARTERS, YOU SHOULD THEN ADJSUT FOR BEST PERFORMANCE. GOOD LUCK.
