hey guys, you helped me awhile back with great info, i wasn't able to do anything with it, but oh well. I had some kind of coil/distributor/condensor/points?? problem, could not work it out, got the new holland folks to help rebuild the whole bolt on unit, still didn't work for me. so, finally when had time took whole '48 8n down to them and said get running. cost $400. they said I probably had more problems from letting it sit for the 5 months it took me to mess around with it than whatever the original problem was(stuck valves, etc, etc, also had them convert back to 6V pos grnd from 8v neg grnd). have been perusing the archives and noticed all the "overheating" entries, then on page 3 or 4 of 25 of my search, all i could get from that or any other search is a list of non-links with the date 12/31/69???the thing was running fine for the 3-4 tanks of gas that i actually owned it and then died, finally got it fixed, is letting it sit that long that bad? have seen numerous posts mentioning letting it sit over winter and no mention of that being real hard on the engine. the thing runs kinda flakey, the idle adjustment screw won't sit still, but i can keep it going and it doesn't take long for it to start feeling real hot, it did not feel hot like this before. when I shut engine off, i can hear the radiator boiling and some fluid burbles out, but nothing is coming out while it is running. i opened up the bleeder coolant valve and let some run over my fingers and that didn't seem all that really hot, i think my morning coffee would have burned more? I also tried to feel for a thermostat in the hoses and I don't think one is there, unless it's a real flexible thermostat, but that would cause underheating, i got boiling radiator fluid in about 5 minutes. just a few questions: am i close to damaging engine from overheating? one post said engines run hot enough for him to light a cigar off the exhaust manifold, or is that the exhaust, not engine? because numerous other posts said this engine runs cool. the water is swirling around the radiator so water pump working, could 5 mos. sitting around clog up radiator? was told may have a year or year and a half left in her, needs an overhaul, about $1800, does this seem reasonable, not just the price, but the year and a half left? they did say the best thing now is to try to run it alot and clear out some of the rust they found in the engine and it should come around some. thanks for any info, sorry about how long and rambling this post is, hope it makes sense, it's 3 am and i'm going to bed. p.s. This is an amazing board, the number of posts and the quality of the respondents, it's a great knowledge base at our disposal and I am very greatful, please keep it up. rob
