Order Ford 8N Parts Online
Air cleaner door on 8N
Rob
09-21-2000 16:06:45
I just got an air cleaner door for my 8N from Central Tractor. Is this part supposed to have a screen that fits under it to keep trash out of the air cleaner? The louvers seem like they are large enough to let a lot of stuff get in.
The guy I bought the tractor from just had a piece of old porch screen stretched over the hole, which worked fine, but looked tacky.
Also anyone have any idea where I can get the screen that goes over the grill of an 8N. i have seen it in pictures, but never seen one for sale anywhere.
I use this tractor for cutting hay, and bushogging, and the raditor plugs up with grass seed, and ragweed pollen an the tractor starts to overheat unless I go to th shop and blow out the raditor with an air hose.
Gaspump
09-21-2000 20:18:58
 Re: Air cleaner door on 8N in reply to Rob, 09-21-2000 16:06:45
The air cleaner door is supposed to have a galvanized and painted 1/8'hardware cloth screen behind it cut to shape. You can make one.
Paul - Pine Island MN
09-21-2000 19:22:58
I believe Palmer Fossum has the grill screens with the Ford logo. He is at 507-645-8095.
bobeque
09-21-2000 16:39:48
rob: also, screen door screen (the aluminum stuff) seems to work well. No ideas on the grill screen. I think some parts suppliers might offer some. FWIW
bobeque
09-21-2000 16:36:41
rob: IMHO if you put the wire screen on the inside of the door, it can't be seen and therefore looks and works at its optimum.
