RPM'S
BOB [PA]
10-15-2000 15:28:36
IS THERE ANY WAY TO CHECK RPM'S ON 1941 9-N THANKS FOR ANY HELP!
Corky
10-17-2000 07:11:37
 Re: RPM'S in reply to BOB [PA], 10-15-2000 15:28:36
You might check with a hobby shop that sells remote control airplanes. I think they have a device that they use to determine the RPM's of the model airplane engine. Good luck
Corky
rbell
10-16-2000 08:07:08
I worked with a machinist that had a small device he could hold against a spinning shaft to tell the rpms, it only went to about 1500 if thats enough. Test device only not a permanent solution. Available at machinist supply houses
STUMP PULLER
10-15-2000 18:13:01
THE BEST SOLUTION IS A CAR TACH. GOOD LUCK
gobcat
10-15-2000 17:43:47
you could count the fan blades and divide by 4, or three` or whatever.
