Order Ford 8N Parts Online
8N steering gear backlash
BHFLA
03-03-2002 09:25:44
I am currently in the process of rebuilding my early steering gear on my 8N. I have the manual but I need assitance with one item. When you rotate the sector shaft eccentric to eliminate backlash, I don't know exactly how to check this. What is backlash? In a vehicle rearend you put paint on your gears and check the proper mesh from your pinion gear to your ring gear. Is backlash on the 8N steering just free play? Any help will be greatly appreciated and thanks to all in advance!
Claus
03-03-2002 10:12:29
 Re: 8N steering gear backlash in reply to BHFLA, 03-03-2002 09:25:44
Yes, the backlash in the steering is the free play. Early 8N steering engineering leaves a lot to be desired. That is why they came out with the tapered sector gears. On the old 8N, as you bring the front gear closer to the rack, you are also increasing the distance between the left and right sector gears and then hope you can bring in the back sector...
Happy Motoring
Claus
