Tires
B0b Parsons Az
04-25-2002 13:48:49
Where can I order front tires (4-19size) for my 2N tractor? I also need tubes.
Bob
Bill MacPherson
04-26-2002 13:33:46
 Re: Tires in reply to B0b Parsons Az, 04-25-2002 13:48:49
I have 2 tractors with 400-19 , I have had no problems getting name brand tires at local Good Year dealer ---Bill
Bob Parsons Az
04-26-2002 17:40:20
 Re: Re: Tires in reply to Bill MacPherson, 04-26-2002 13:33:46
Thanks Bill, I called a nearby Goodyear tire dealer and they had three in stock and about 50.00 dollars each. Thanks again
Bob
Richard(WY)
04-25-2002 22:05:26
Try Tucker Tires. best folks around to do business with. Ask for Junior, tell him that Bubba sent you and you will get a ministerial discount. I bought tires and tubes from him for my 4X19 rims, well satisfied with them.
Tyler (MD)
04-25-2002 15:10:46
Miller Tire sells single rib, and tri-rib tires for your needs.
third party image third party image third party image
Tyman
Dell (WA)
04-25-2002 14:12:30
Bob..... ..unless you're really into "originallity" I'd at least look at some used knobby motorcycle tires for your 4 X 19 front rims. Tractor's not carrying much frontend weight and you're not driving that fast eather (grin) New innertubes and unless you're into thorn problems, (use slime) you're good to go..... ....Dell
dave#1
04-25-2002 14:51:31
 Re: Re: Tires in reply to Dell (WA), 04-25-2002 14:12:30
That's the second time I've heard to use motorcycle tires, that's not a bad idea at all!
later,dave
Steve IA
04-26-2002 09:23:52
 Re: Re: Re: Tires in reply to dave#1, 04-25-2002 14:51:31
Murdercycle tires might work fine on turf or dirt, but If you're going to the barn lot, Ag tires are much better. They have protection built in to reduce weather checking and rot caused by contact with manure. The amount of antioxidant and antiozonant oils added to non-ag tires is less but is usually not needed as the tires wear out and are replaced before the rot sets in. But for $30/tire it may not be a big deal. Can you buy motorcycle tires for $30? My 2¢. Steve 8N 169302
Try a search on EBAY for TUCKER TIRE NT
04-25-2002 14:06:23
m
Ken N Tx
04-25-2002 14:24:13
 Re: Re: Tires in reply to Try a search on EBAY for TUCKER TIRE NT, 04-25-2002 14:06:23
Try www.google.com its a search engine....You will find anything on the Net..... ....
