Hydraulic question
1946 2N....Barn
06-20-2002 13:46:39
I decided to put my '46 2N to work. It has set around "looking pretty" for two years. I was using the rake and I'm getting up pressure on the lever. It is enough for the hydraulics to raise the rake all the way up without me touching the lever, which comes up also.
Truthfully, I have not picked up my manual to read it(Hi, Dell). I just happened to be taking a little break and thought that I would see if anyone has had similar experience.
Scott
06-20-2002 18:34:13
 Re: hydraulic question in reply to 1946 2N....Barnstormer, 06-20-2002 13:46:39
Your friction disc needs tightened or replaced on the lift lever pivot.
Barnstormer
06-20-2002 18:49:05
 Re: Re: hydraulic question in reply to Scott, 06-20-2002 18:34:13
I'll take a look at that this week-end. The upward force seems greater than any force that I have ever applied to the lever, up or down.
ZANE
06-20-2002 15:56:58
You need to install a ZANE THANG position control device for the tractor.
See the link below/
Barnstormer
06-20-2002 18:33:26
 Re: Re: hydraulic question in reply to ZANE, 06-20-2002 15:56:58
Hi Zane, I've got one, still in the box (next to my hydraulic adjustment tool). :>) I was planning for it to go on another tractor. I've just never experienced such up force on a control lever before. Neither of my other 2 working 2N's have done this and I can't ever remember any 8N doing it, or at least none that I have owned.
ZANE
06-20-2002 19:07:48
 Re: Re: Re: hydraulic question in reply to Barnstormer, 06-20-2002 18:33:26
Tell me again exactly how the lift acted that seemed to be unusual since you have other Ns you should be familure with what is going on.
Barnstormer
06-21-2002 04:13:10
 Re: Re: Re: Re: hydraulic question in reply to ZANE, 06-20-2002 19:07:48
Goodmorning, Zane.
The symptoms: I lower the hydraulic lever and get a backfeed pressure trying to move the lever up. If I let go of it mid-range of the quadrant it will come back to the top by itself and raise the implement.
If I force it to the bottom of the quadrant, it will stay there most of the time.
