Rope in cylinder trick -- not just for N's!
rob 8N11071 KS
06-26-2002 09:17:21
I've learned so much here.
I used the "rope in the cylinder" trick to remove a starter pulley...on my weedeater! Messed with it for about half an hour trying to get the starter pulley off. Tried various tools and wedges to lock it in place. Came right off with the rope trick.
No useful information, just appreciation.
DaBrow
06-27-2002 05:38:44
 Re: rope in cylinder trick -- not just for N's! in reply to rob 8N11071 KS, 06-26-2002 09:17:21
Used that "trick" on my Harleys for over 20 years....DaBrow.
2NTim
06-27-2002 05:08:26
Ya...cool trick, with one caution. If it's an overhead valve engine, may SURE it's on the compression stroke!
Bob
06-26-2002 14:29:47
What exactly is the rope trick? thanks Bob
Bryan (CA)
06-26-2002 15:26:23
 Re: Re: rope in cylinder trick -- not just for N's! in reply to Bob, 06-26-2002 14:29:47
You put some of a piece of 1/4" soft cotton rope down the spark plug hole. Then you turn the crank (by hand) until the cylinder comes up and mashes the rope up against the head. The idea is this will either a) prevent the crank from turning so you can unthread whatever is on it or b) pop the head off (if the head bolts are removed). Oviously you don't want to use the starter to turn the motor over (unless you're going for option b)
Dave Smith
06-26-2002 18:14:52
 Re: Re: Re: rope in cylinder trick -- not just for N's! in reply to Bryan (CA), 06-26-2002 15:26:23
I would be very hesitant to use the starter. The inertia might be too much and you could bend a rod or break something.
Dave <*)))><
Bob
06-26-2002 18:03:15
thanks for the tip! It will come in handy some day. i never would have thought of that. Thanks Bob
Jim.UT
06-26-2002 16:11:45
I imagine it would be a good idea to tie a long bolt or stick the end of the rope if you're going for option A. Could be a trick fishing that rope back out of the spark plug hole if it all falls in.
tie a knott in end . . . Dell (WA)
06-27-2002 08:01:03
 Re: Re: Re: Re: rope in cylinder trick -- not just for N's! in reply to Jim.UT, 06-26-2002 16:11:45
simpler
