Gasket sealer for oil pickup tube?
Rob
07-16-2002 10:13:09
I'm slowly getting things back together as time and parts become available. I'm at the point of reinstalling the pickup tube to the oil pump. As this is a particularly critical seal point, I assume I should use a gasket sealer of some sort to help out the paper? If so, what's receommended?
I have packed the pump with vaseline, so I'll need to clean up the mating surfaces prior to installation. I've seen archive recommendations for using the spray type gasket sealer on the gasket and letting it dry before installation. Is this a good way to go on this one?
Thanks.
Rob
Bill Hires
07-16-2002 15:38:29
 Re: gasket sealer for oil pickup tube? in reply to Rob, 07-16-2002 10:13:09
I would not put sealer of any kind on that gasket, put oil on it and mount the oil pickup. I hope you are talking about the thin paper gasket that came with the overhaul gasket set.
Rob
07-16-2002 19:20:39
 Re: Re: gasket sealer for oil pickup tube? in reply to Bill Hires, 07-16-2002 15:38:29
Yes I am, and thanks for the reply. I was beginning to think it was just a ridiculously dumb question, or nobody knew for sure...!
Thanks again.
Rob
