Order Ford 8N Parts Online
8N Torque / Ft. Pound Settings?
Barry 51 8N
07-23-2002 07:41:28
I am diligently attacking all hydraulic oil leaks on my 51 8N.
Can someone please let me know what the torque settings on the
main drive shaft and PTO end cap bolts, where they just enter the tranny are?
I am installing new gaskets in each.
Also need the torque settings for the axle housing trumpet bolts where they connect to the center differential housing. The bottom 3 point hitch pin is leaking also. Thaks in Advance,
Barry in Vermont
JimNC
07-23-2002 16:20:51
 Re: 8N Torque / Ft. Pound Settings? in reply to Barry 51 8N, 07-23-2002 07:41:28
Here is a link for standard torque values. If you use these you will be ok. If there is a torque given for a head bolt or con/rod, main use them. If no torque is given use the standard torque value for that fastener.
