Size of chain harrow
BHFLA
08-06-2002 08:13:15
I have a 1949 8n. I have found the need for a chain harrow. My question is, which size works best behing a good running 8n? Localy some have recommended a 4 footer while others have said a 6 footer would work. I want to get the six foot model so it will cover the back tires. Any ideas or suggestions would be appreciated. Thanks all in advance.
Alan
08-06-2002 09:44:19
 Re: Size of chain harrow in reply to BHFLA, 08-06-2002 08:13:15
I use one that is in 2 sections ...each section is 3 foot wide x 4 or 5 foot long...You connect the sections together with links....makes for easier handling ....Mine also is reversible ...It has tines on one side and flat on the other....I use mine for 2 reasons...1) it really smoothes out a seed bed well ....2) I do turn over ground that is old sod and brush...after plowing and disking it picks out allot of the sod clumps/brush roots that didn't get turned over real well....You have to clean it quite often though....The 8n pulls it fine...Good Luck....Alan
