Tractor Identification
Rob 9N
09-04-2002 18:08:30
Howdy all, I have a friend that has an N that I've been looking at for a while from a distance. I asked him about it and got some vague answers. Then his house burned to the ground. So he was not around and out of respect I didn't go down there to check on the tractor. My question is how to tell the difference from a 9N, 2N, and 8N. He said it had a front mount dist. 3 forward gears and appears to be stuck in gear(according to the tractor shop). Apparently it does not have position control(He has been using chains). Any help would be greatly appreciated. Thanks in advance; Rob
ernie
10-15-2002 12:25:51
 Re: Tractor Identification in reply to Rob 9N, 09-04-2002 18:08:30
it is a old cg7 wheel horse and iwant to find out what yearit is and what horsepower.
mark
05-24-2003 16:46:50
 Re: Re: Tractor Identification in reply to ernie, 10-15-2002 12:25:51
i need to no what kind of coil will fit my mower model-252707
type-0202-01
code-81031711
Bob in NY
09-04-2002 19:44:43
Just look to the left side of the page, under "Serial numbers", click it, Ford, and 2n, and it will give the years and serial numbers. On the tractor, the serial number is hand stamped on the engine block, drivers' side, near the oil filter. 2N's are stamped "9N", so don't be confused. Bob in NY
Ron from Ohio
09-04-2002 18:42:32
Well an 8N has the right and left brake on the right side and a 9n has the right brake on the right side and the left brake on the left side with the clutch. Hope this helps.
soundguy
09-04-2002 18:15:30
Sounds like a 9n/2n. My 8n has 4 gears and I believe all ( most? ) stock 8n trannies are also 4 gears. Also, we have position control, as well as draft.
As for the 9n/2n... have to let one of the masters here answer you.
good luck.
Soundguy
Dave Oh
09-04-2002 23:26:21
 Re: Re: Tractor Identification in reply to soundguy, 09-04-2002 18:15:30
"Soundguy" is correct. Only the 8N's had 4-speed forward. So it is either a 2N or 9N.
Your serial number will start with (9N) in either case. Also check the casting number on the rear end to get a date & year. Many engines were changed over the years.
Dave OH
