I used Zane's method with good success on .090 sleeves. In retrospect, I found it better to follow his instructions exactly, rather than trying hybrid schemes that I cooked up from reading the archives. You can't beat "the voice of experience". You can use a Mig welder to run the three beads to shrink the old sleeves. Use the same settings you would to weld .090 steel. An ABS pipe plug is almost the right size to use as a poor man's driver to push the stubborn ones out once shrunk. I tried freezing the sleeves. Visions of "they'll just drop in". I froze them for two days. Set up the block right next to the freezer. Had a block of wood and an 8 pound sledge. Bad idea. While a 50 degree temperature difference should, in theory, be enough to eliminate the interference fit, in practice the heat transfer from the warm block to the cold sleeve is so effective that you only get an inch or two of "it just drops in" before the sleeve expands and hangs in the block. Then I tried to tap it down with the block of wood. This works until you get to .25 inch or so of the block, but by that point top of the sleeve had embedded itself in the wood and I couldn't drive it any more. I successfully resisted the (strong) temptation to tap on the top of the sleeve, "just a little bit", with the sledge hammer. Then I went out and did what I should have done in the first place and bought a "Zane Whang"; a 6 inch x 6 inch piece of 1/2 inch steel plate. All the sleeves drove in fine; you have to hit them pretty hard but the plate spreads the force out evenly across the top of the sleeve. Two additions to Zane's advice. Make sure you thoroughly clean out the counterbore that receives the flange at the top of the sleeve. Carbon or crud may cause the sleeve to hang up prior to going down the last .020 inch or so. "Even with the deck of the block" is a bit subjective. There can come a point where the sleeve just doesn't seem to want to go down any more, but is still standing "proud" of the deck by .003 or so. The counterbore isn't quite deep enough to receive the flange, or maybe the block is a little bit warped. Ford actually recommends that the block be deliberately machined this way when retrofitting an engine from thin sleeves to thick sleeves. I suppose the top of the sleeve acts as something of an O ring against the head gasket. So don't keep beating on the sleeve once it seems to be firmly seated, provided it's within .005 of the deck. Regarding "oversized sleeves": my Dad let the maching shop talk him into using something like this on our 9n 40 years ago. Something about "more power". The sleeves didn't fit right, and one of them went up and down in the block with the piston. "Tick-a Tick-a Tick-a", as the sleeve hits the head, is a sound I will always associate with the N-series. We tried 3 or four times, over the years, to find a way to secure the sleeve to the block. I can still hear my Dad muttering "I should never have used those oversized sleeves..." The standard sleeves have the advantage of a broad experience base, having been used in thousands of tractors. Some hot-rod sleeve, who knows?
