Lower rebuild
Rob 9N
01-19-2003 00:53:40
Just kinda thinking out loud, I'm wondering if it would be a good idea to just rebuild the block on my 2N instead of doing the whole thing. The engine starts quick and runs great. Just after a few second you can hear a rod starting to knock. I do have a crack in the block but I think it might be alright, Is this advisable? All opinions highly appreciated. Thanks, Rob
Rob 9N
01-19-2003 07:02:43
 Re: Lower rebuild in reply to Rob 9N, 01-19-2003 00:53:40
Thanks for the response. I guess my concern is would there be any reason to rebuild the head if it seems ok? Like I said, the engine woks beautifully with the exception of the knock. Thanks. Rob
SteveB(wi)
01-19-2003 08:54:04
 Re: Re: Lower rebuild in reply to Rob 9N, 01-19-2003 07:02:43
Not much to rebuild on a flathead's head. Clean it up, look for cracks, check for warpage. Valves are in the block.
raytasch
01-19-2003 06:15:43
Rob, Many block cracks can be successfully repaird by welding or one of the many commercially available materials. Some cracks can NOT be successfully repaired. An engine that is knocking very seldom gets any better, usually gets worse and does more damage the longer it is run. But you probably know this if you can identify an rod knock.
ray
duey
01-19-2003 01:31:20
Rob, the crack in the block is clearly YOUR call, but a failing rod may spell the end of the block AND the useability of the tractor... If the cracked block just leaks a bit of coolant, that may well be liveable.... a rod thru the side (or bottom), isn't. Your call..... duey
