Order Ford 9N Parts Online
9n gas tank color
Rob Mo.
02-03-2003 17:35:11
There has some controversey here. What color does the 9n gas tank get painted or is it acceptable as bare metal.
MarviN (OR)
02-03-2003 18:57:26
 Re: 9n gas tank color in reply to Rob Mo., 02-03-2003 17:35:11
The Petersen & Beemer Book (Ford N Series Originality Guide) lists the gas tank as being cadmium plated. I believe this was another name for what we call galvanizing. Most paint stores will sell a product called 'Cold Galvanizing Compound'. This is not a shiny bright finish but is more a dull lighter gray than the normal 9N color. It should be gas and corrosive resistant like David said (should you spill gas and it gets under the hood where you can't wipe it off).
BTW the book also notes the wire tube that runs along the top of the engine being 'cadmium plated' also.
Just my opinion from my experiences, yours may vary.
David - OR
02-03-2003 18:07:44
The tank was cadmium plated steel. Kind of a gray-black in appearance. The paints of the day could not tolerate the occassional gas spill, so rather than have have the paint get washed off the tank and run onto the engine, they cad plated the tank to forestall corrosion, and left the paint off.
Modern epoxies and urethanes can resist gasoline much better. You can paint it to match the hood or the engine.
Alternatively, Eastwood sells a "Cad plated look-alike" paint, if you want to touch up the tank and retain that factory original look.
It is desirable to retain the cad plating, rather than sandblasting it off to bright metal, should you plan to paint it.
DC
02-03-2003 17:57:23
Go to nseries.com and click on paint information and its gives all the n series and what parts should be painted what inc. the 9n
Paul8n
02-03-2003 17:41:26
I believe it was a color such as zinc or something. I can't remember but someone will. HTH
Rob Mo.
02-04-2003 11:00:05
 Re: Re: 9n gas tank color in reply to Paul8n, 02-03-2003 17:41:26
What if I just spray an automotive clear coat on it? I did that once with a fibeglass fertilier bin on me old Ford planter. What does ya'll think of that?
