Batteries and solar panels.
BC Mike C
02-11-2003 17:03:07
If I was to use a solar panel to keep a 12 volt battery charged what size is suggested? To stop any corrosion on the terminals would regular grease be okay or is there a better substance? Can it be applied between the surfaces or should the cables be connected and then have the goop applied? Thanks BC Mike C
soundguy
02-12-2003 10:51:32
 Re: Batteries and solar panels. in reply to BC Mike C, 02-11-2003 17:03:07
Solar chargers are a great idea. In college, we did quite a bit with solar cells. The biggest peroblem to overcome is charge rate. Contrary to popular belief... a solar charger will charge a good condition battery that is otherwise just discharged... but keep in mind the charge rate.... a battery that charges up in 8 hours on an 1 or an amp and a half charger is gonna take a looooo ng time om a 100ma or 50ma charger. And take into consideration no charging at night, and only getting full charge in full sunlight.
I use solar powered electric fence chargers for some of my animal pens that are way out in the pasture, and they have been going for a couple years.... a 4v and a 6v model.
When I did electronic repair alot, I used to carry a jar of vaseoline with me.. works great on the electrical connections.. and easier to clean up than silicone goo . I see no reason why grease wouldn't work...it displaces moisture.. may contail metal protectants, fills voids to prevent air contact , etc and does a decent job at debouncing ( arcing on contacts for switches...NOT POINTS! )
Soundguy
dale b
02-12-2003 08:01:53
mike. i have a hunt camp that is powered by solar. off grid, as they say.
i have 2 marine batteries that i fully charge at home. i have a solar charger that maintains the battery, not charges the battery. i use lights , tv , and a fan. depending on how long you use things, it will last for about 3 days per battery.
i bought my solar charger off ebay for about $20. it is the charger that came with the new v.w. jetta.it works good, and it was cheep.
i also have a crank up radis, and i love it.
sorry for not really answering your question...
there are solar charger that are used on a motothome that will CHARGE the battery, but they are lots of $$$
check on ebay under SOLAR and you will be amazed at what is out there.
dale b
Don H
02-11-2003 22:12:10
Not to familiar with the solar stuff but very familiar with battery terminals. When I was in the army they had us use grease on the terminals. It must have been the best thing money could by. If they could have found anything more expencive they would have bought it. Clean the connections real good then apply the grease before putting them together. The grease will be squeezed out and make an air tight connection. Do this 2 times a year and you will never have a bad connection again. I have not had a bad connection in over 30 years doing this. Don
BC Mike C
02-12-2003 09:41:39
 Re: Re: Batteries and solar panels. in reply to Don H, 02-11-2003 22:12:10
Thanks Don, that's what the logging contractor down the road told me the other day. Said it works for him and now you have confirmed it. I drained the diesel out of my boat and gave it to him for one of his big machines, and he gave me a new industrial strength battery, and the grease advice, and that's what got me started on this discussion. It makes me feel bad knowing they may be sitting sometimes with out a full charge, but I will fix that with a solar panel. BC Mike C
Upper Peninsula, Mich.
02-11-2003 19:57:30
Hi Mike. I use a small 12 volt solar panel to maintain the charge in my 12 volt battery operated wild game feeder. cost about $30.00.You can also get 6 volt charges for the same price. Have used it for about 6 years and the battery is still fully charged. I run my camp on two 12 volt battery packs, charged by the gen set. I use a red spray on all connections purchased at WalMart. Find it near the car batteries. Good Luck. Ron
BC Mike C
02-11-2003 19:16:32
Here is some info on the units I looked at today.
A unit 14 X 14 inches 350 mAmps 5 watts $100-. A unit 13 X 38 1 amp 15 watts $200-. A charge controller $50-. The smaller unit looks handy but I am thinking it may not be big enough. I could use the unit for multi tasking, on the boat, the tractor, the camper, the truck that is not being used. When the batteries are near I use a regular small charger. BC Mike C
GregWis
02-11-2003 19:03:24
Mike, If the panel doesnt contain one, be sure to put a diode in between your battery and the panel. Otherwise when the sun goes behind a cloud, your battery will be discharging into the resistance of the panel.
Bishop
02-11-2003 18:43:05
Before I retired three years ago we lived in Atlanta Ga. My 52 8N lived under a tarp in Sunset La. It's still 6V and I had a $30 12 volt solar charger connected to it under the light colored tarp. I blocked out about 1/3 of the screen on the 12V solar charger and it was charging at at rate of 8 volts. It can not charge a low battery, it maintains the existing voltage.
You can buy bigger solar charger that can rebuild the charge completely, at a cost out of my budget.
Mountainman
02-11-2003 17:52:57
The size of the panel depends upon how many hours you expect it to be in the sun each day. Bright overcast days also charge some. Northern tool has some solar chargers in their catalog - I'm sure there are other sources near you.
I know they make a red 'goop' especially for battery terminals but is it better than grease? No telling.
I would put the goop on after the terminals are connected - clean bright & tight.
hth
Mountainman...CA
MikeC
02-11-2003 17:28:14
I don't remember where I saw them at but I have seen solar powered battery maintainers. Kinda like a small trickle charger that has a solar panel that you put in a sunny window.
