Gas tank interior rust
Rob Mo.
03-02-2003 19:48:08
Need help on how to elminate the rust for inside my tank. I hate to just throw it away when it isn't even leaking. What do ya'll suggest?
BL
03-03-2003 14:50:32
 Re: Gas tank interior rust in reply to Rob Mo., 03-02-2003 19:48:08
Take it to a radiator repair shop. They can clean it up and coat the inside.
Patrick (NJ)
03-02-2003 20:13:31
No reason to get rid of it. Clean it out real well....some folks put gravel and solvent in it and slosh it around a bit to loosen up the rust. Buy yourself some tank reconditioner. There are a couple of brands...I think POR-15 is one and Don B sells one as well (may be the same). The treatment consists of a rust remover, a degreaser and then some type of sealer/liner. The tank will be good as new when you finish.
Good luck!
Patrick
kraig WY
03-02-2003 20:04:35
I don't know what size of tank you're talking about. I had the same problem with a 78 Chev 350,( it was clogging the fuel filter) It had two 15 gal. tanks. I put a qt. of oil in each tank (when full) and it took care of the problem.
