Oh Happy Day!
Rob 9N
03-03-2003 16:36:24
I finally got the clutch free on this 47 2N. I took the advise of this board and clamped the clutch pedal down when I got the beast. That was back in November. I was fooling around today,(the first sunny day in a while), and accidently put it in gear while it was running. Got out of the barn and thought, I ought to go for it. I can always tow it back with Francis, (1940 9N). I openened it up and the clutch freed up. Now to address the noise in the front of the tractor. I can't tell if it's a knock or if I have a bad water pump. Any help would be appreciated. Thanks for everything! Rob
Uppe Peninsula,Mich
03-03-2003 17:59:41
 Re: Oh Happy Day! in reply to Rob 9N, 03-03-2003 16:36:24
Hi Rob. I had a funny noise in the front of my 9N and thought it was the water pump. Found out it was the fan blades that were loose. Took them off twice and tightened up the rivets.(Hit them with a hammer) Finally worked the second time. Check your blades,it may save you a water pump. The noise generally only occurred when shuting down the tractor and it was quite loud. Tractor sounds like a new one now. Good luck. Ron
