Too cold 46 Farmer will not start
BC Mike C
03-07-2003 18:22:36
Today was supposed to be my first day of farming for 003, had plans to move manure to the blueberries but at 20F I could not get this 1946 model farmer to start. Operating range is best between 40 and 80F. BC Mike C
try Carharts . . . Dell (WA)
03-07-2003 22:13:06
 Re: Too cold 46 Farmer will not start in reply to BC Mike C, 03-07-2003 18:22:36
Mike..... ..know what ya mean. I wear insulated artic Carharts full zip up the outside leg. Sometimes a little extra "sweetnin" in the kauphy helps to get things going too..... ...Dell
BC Mike C
03-08-2003 10:31:39
 Re: Re: Too cold 46 Farmer will not start in reply to try Carharts . . . Dell (WA), 03-07-2003 22:13:06
10F this morning, since warmed up to 20, got the 46 farmer started then the 41 9N ( that was the easy part ) put air in the tyres, after the hose broke had to use a $10- 12volt unit. Greased the chains and gears on the spreader, told the farm boss we have to look after it now that we bought out the neighbours share. Having a coffee break ( Mark's advice ) now I have to go see if the neighbours 35 hp MF diesel will run. I need the bucket to load the manure into the spreader, then I unload the spreader at the end of the blueberrie rows. BC Mike C
Willy-N
03-07-2003 18:27:19
Put some more cloths on and have another cup of coffie to get going! Mark H.
