Back the tractor up to the bush hog. Drop the touch control down. Try to line the lift arms up with the pins on the hog's frame. Turn the tractor off. Make sure the PTO selector is full forward. Slide the eyes of the arms over the pins, insert linch pins. If you have a stabilizer arm that goes from under the axle where the fender mounts, hook it up as well. Then attach the top link from the top of the differential to the top of the hog frame. Adjust the top link to take up any slack. Connect the PTO drive shaft to the PTO. It would be best to have an over-running coupler. If you don't have one get one. The tractor shaft is 1-1/8" and the common PTO is 1-3/8". So unless the shaft has been changed, you'll need an ORC that adapts from 1-1/8" to 1-3/8". Once the hog is hooked up, climb aboard, start the tractor, make sure the position control lever under the right front corner of the seat is in the vertical position, engage the PTO and lift the touch control enough to get the hog off the ground. Don't lift it all the way up until you know the drive shaft is not going to hit the front of the mower deck. Push the clutch in, disengage the PTO, drive to where you want to mow. Drop the touch control, engage the clutch until the transmission stops turning and you can engage the PTO lever, put it in 1st or 2nd gear, give it 3/4 throttle and let the clutch out slowly until the mower and tractor start to move.
