Ok, Lets see. I was told by the place that rebuilt my genny that around 20 was the max.. and most likely 15-20 was closer to reality. I believe the older ones on the 9/2 N ( 1 wire jobs ) were rated for 11 amps or so. Ok, on the top post, one will be field, and will be insulated by a fibre washer. The other post will be directly to the ground of the cast.. will not be insulated at all.. just a stud common to the outer casing. The large stud on the rear is the output. Should be higher than 6 volts.. should be around 7 volts.. or so.. from there to ground. ( Your tractor was originally positive ground ). Ok, att he regulator, there will be a batt terminal,, that is tied to the batter either at the hot stud on the solenoid.. or directly to the battery cable.. depends on the previous owners wiring. There you will measure charging voltage.. should be higher than 6, to charge. The battery should measure 6 to 6.5 volts or so just sitting there... probably closer to charging voltage right at shutdown.. and closer to 6 if it has been sitting for a few days. Some of these are approximates, as real measurements will be effected by the condition of the genny, and regulator, and how good the wires and connectios are, including condition of the battery, and whether or not someone has adjusted the regulator any. Just curious.. why do you ask? is your charging system having a problem? or just for reference sake. Soundguy
