2 things I wouldn't do... 1 is mow 5 acres with a riding lawn mower.. just too much time involved.. and prematurely wears out the machine.. plus I'de have to quit one of my jobs just to find time to mow... 2nd.. is drop close to 3g's on a riding mower.. for one.. you are close in price to a comercial mower... and they will literally run circles around a rider... not that I like the comercial mowers / ztr's.. Also... that price probably will buy you an N... or if you already have a tractor.. will buy you a finish mower with money left over. What kind of problems is the sears having? deck problems or engine / tranny problems. If only deck problems I suggest you trash the deck and get a tow behind trail mower.. they have their own engine, and mow real nice. ( I have a craftsman tow behind .. ) They start around $700. Way cheaper to get one and pull it with an existing atv or mower with a trashed deck... or even pull it behind another mower and offset it and make wide cuts. I have my tractors and big mowers for the pasture, and I have a push mower for right around the house. For the rest of the small work I use a little murry.. ( 12.5 hp 38" cut ) I got about 5-6 years ago... a great machine. I've never had a problem with it.. just maintenance stuff... Have put on a set of blades, and changed the battery once. Before I fenced in the front yard and added it to the pasture for the horses and cows, I used that little murry and the 48" craftsman to make about a 7' pass at a time. A neighbor cuts his the same way.. only he has a large huskee like 20 hp and 52" cut, plus a 42" trail mower. It's your money.. but I just can't see sinking that much into a machine that is going to wear out fast on 5 ac... think about a tractor and finish mower.. besides.. it will save you lotsa time. good luck! Soundguy
