Proper placement of axle shaft shims
'52 8N (MD)
05-29-2003 17:14:07
Okay, the master parts catalog (p.58) shows shims (4229) on both sides of the brake dust plate. When I took the left axle apart the shims were between the dust cover and the axle housing. The right axle had the shims between the dust cover and the bearing retainer. Since the MPC shows both, which is correct? TIA, WC
DallasGa
05-30-2003 05:18:48
 Re: Proper placement of axle shaft shims in reply to '52 8N (MD), 05-29-2003 17:14:07
They were originally between the dust plate and the retainer however either location will produce the same effect.
Mike OH
05-29-2003 18:08:14
What I did was to place only one shim (paper) between the dust cover and the axle housing and remaining shims (metal) between the dust cover and the bearing retainer. The reason I use paper and metal was some of the original metal shims were damaged so I replaced with paper.
