Left brake binding with clutch pedal
'52 8N (MD)
06-04-2003 06:49:40
The left brake pedal stays partially down if the clutch pedal is also down. The brake pivot arm (that goes through the body) rides on a bushing in the clutch pedal which is no longer available. I tried teflon tape but that only took care of the slop, not the binding. Best advice aside from custom bushing from a machine shop or taking a chance with used part? Tx, wc
Do you have the part numb
06-04-2003 12:47:19
 Re: Re: Left brake binding with clutch pedal in reply to DallasGa, 06-04-2003 07:25:00
Dallas, thanks for the tip. The Master Parts Catalog shows a 8N-7508 A & B. Any idea which one it is? The reason I ask is that my 8N is a late 1952 (s/n 483604) and the split bushing is only supposed to fit the earlier models. Thanks Again, wc
DallasGa
06-04-2003 19:36:31
 Re: Re: Re: Left brake binding with clutch pedal in reply to Do you have the part numb, 06-04-2003 12:47:19
Ha MD,Don has it listed as 7508A,thats the ones I used,althought master parts says A is the trans bushing and B is the clutch.The only differance is the hole for grease in the clutch,My trick should work for you.
