Radiator Cap
Rob N VA
06-09-2003 08:50:07
The radiator on my 8n looks a little shady. I just got the tractor (my first) about 4 months ago. I had the hood off a few weeks ago to do a rewire, and noticed that the radiator had a "2n" stamped on it. The overflow tube on the neck has been gone for what looks like a while, and the radiator cap looks like something someone got off a junk yard to just get by. So far, no overheating problems. But does the overflow tube and the radiator cap make a difference? Should I attend to these things before the weather gets really really hot? Thanks in advance for the help
Rob
Pete
06-09-2003 12:55:36
 Re: Radiator Cap in reply to Rob N VA, 06-09-2003 08:50:07
Rob --
If you have a front mount distributor, I may differ from Durk's view Re the overflow tube. If the radiator pukes out some water and there's no tube to guide it to the ground, it could splash onto the front of the engine. If your distributor is up there, so long spark (at least it happened that way on my 9N before I got the radiator fixed up.)
I agree with needing a proper cap in any event.
Hope this helps,
Pete
Durk(OH)
06-09-2003 09:03:39
I wouldnt worry about the broken off overflow tube but the wrong cap might cause some problems. try TSC for a new cap or your local ford new holland dealer or w w w . j u s t 8 n s . c o m
