Are there bushings in the front wheel spindles
B Cook
06-12-2003 05:57:57
My dad says that something is tight by the spindles and he thinks that the bushings might need to be replaced but isn't sure if there are any to begin with. Are there or aren't there?
Claus
06-12-2003 06:31:58
 Re: Are there bushings in the front wheel spindles in reply to B Cook, 06-12-2003 05:57:57
Yes, there are 2 bushings per spindle. If you replace them, try to get the rolled bushings if the spindle is not worn. They also come in the type that have to be honed. This is if the spindle itself is worn and the bushings can be fit to it.
When replacing the bushings, also replace the thrust bearing on the bottom....
Happy Motoring
Claus
