Order Ford 8N Parts Online
2 belts sizes for 8N's.
Rob
06-13-2003 11:32:36
Local F/NH stocks the long belt for the front mounts. That's the B43 or 45". Parts guy said it was about the water pump pulley size. I have the side mount which the shorter belt, 1950-52 and 1953 it seems. Book says it's about the genny pulley.
Seems like there are a couple of fan/water pump pulleys and a couple more generator pulleys. Imagine there are some unintended combinations on these tractors by now. My 8N will be good. No way the genny pulley will interfere with the axel travel. It's all tucked up inside under the hood.
Scott
06-13-2003 16:19:27
 Re: 2 belts sizes for 8N's. in reply to Rob, 06-13-2003 11:32:36
For the 9N there are 2 choices of belts depending if a 1939 or early 1940 that has the small generator (9N-A or 9N-B) or if its a large generator (9N-C), an 8N has a different belt depending if the generator is mounted on the right of left side, it should be easy for the dealer to get the right one unless they are new there.
Rob
06-14-2003 09:40:38
 Re: Re: 2 belts sizes for 8N's. in reply to Scott, 06-13-2003 16:19:27
So that would make it a B43 or a 45"-46" for right-hand 8N's and a 41"-42" or the B39 belt for the left-hand. 42 1/2" is all the adjustment used up on the left-hand. Maybe even a B38 or 40". That left-hand/right-hand is sitting in the driver seat.
