Repair Radiator Cap?
'52 8N (MD)
06-14-2003 06:13:16
I searched the archives and saw where most 8N's blow off all extra coolant so the level stays just above the core. That's all fine and that's where mine stays. But I don't believe the old cap holds any pressure. So here's the question: do I refurbish the cap ($15 @ Dennis C.) get a new cap ($12) or just leave the darn thing alone? BTW, I don't know if there's a thermostat in the neck or not. TIA, wc
Scott
06-14-2003 16:09:32
 Re: Repair Radiator Cap? in reply to '52 8N (MD), 06-14-2003 06:13:16
Just drive to your local New-Hol-land dealer, cap around $8.00, upper hose around $4.00 and the thermostat is a little more, there should be plenty of dealers near you in MD.
RoN of ohio
06-14-2003 13:06:16
Just squeeze that upper hose up from the head about 2-3 inches. If there is a thermostat in there, you will be able to feel it. If not, then you should consider getting one. Just my opinion...Ron
Rob
06-14-2003 09:52:51
This cheapskate keeps 1/16" red rubber gasket mat'l around anyway. I cut a new gasket and glue it in the old cap with Loctite Stick N Seal. That seems to be a handy glue. Kind of a cross between the old model glue and silicone. Must cost me 25-cents and 15 minutes. Maybe less.
Very cool solution, Thank
06-14-2003 10:30:24
 Re: Re: Repair Radiator Cap? in reply to Rob, 06-14-2003 09:52:51
Say..John,PA
06-14-2003 07:18:04
I take notice that yuse from below the LINES.
Down there we gits good advise from "ONe OF OUR OWN"!!!!! !!!!! !!
tRY yiNGLING IN TANEYTOWN. HURRY up. hIS GRANDMA is mak'n dinner. ASk for tele. number onb this miraculous network.
END OF TELEGRAM. Hope your'n works better.
Rob N VA
06-14-2003 06:24:37
You gots to have the thermostat. I suppose it all depends on how original you want to keep your N, as to how you fix the cap. They aren't all that expensive either way you go.
