Taking the main mixture screw out all the way, besides enrichening the mixture, has the side effect of venting the float bowl to atmospheric pressure. If this is a new "Not Marvel Schebler" clone carb, try the following tests: Remove the main mixture screw. See how the engine runs. Cover the hole with your finger. See how the engine runs now. If the engine smooths out when you remove the screw, but then roughens back up when you cover the hole, I suspect you are suffering from the "clone carb plastic venturi blocks the bowl vent" bug that seems to be a design "feature" of your new carb. If the engine pulls a load OK, and seems to run fine at higher speeds with at least some load on it, this lends support to this proposition. The term "Chinese copy" is often considered both a compliment and a perjorative. THe copied version is sometimes almost as good as the original, but a lot cheaper. No need for minimum wage, environmental laws, or those pesky workplace safety regulations. he flip side is often times the copies come without sound knowledge of the original design theory and without reasonable post production testing. The entity that copied the Marvel design substituted a plastic venturi for the orignal brass venturi, presumably to save money. The thicker flange at the base covers the passage from the float bowl to the choke horn. This causes the back suction economizer to work overtime, resulting in the rough operation. Removing the main mixture screw provides an alternative means of venting the float bowl. This problem can be corrected by substituting a brass venturi, or by enlarging the bowl vent opening with a die grinder, or both. Alternatively, send the new carb back where you bought it, buy a used Marvel Schebler carb, and overhaul it.
