Carb repair kit
'52 8N (MD)
06-18-2003 08:27:14
The search function isn't working today for archived messages so here goes. I have the APN9590A carb repair kit and there are no instructions with it. Since I only have the 39 page FO-4 manual, it isn't any help either. There are two carb idle jets and three carb economizer jets in the kit. Do I match up with the existing diameter size or try different ones? Any links to instructions for the rebuild heartily appreciated. Tx, wc
uh . . . Dell (WA)
06-18-2003 08:45:57
 Re: carb repair kit in reply to '52 8N (MD), 06-18-2003 08:27:14
On the l/h sidebar is a "Research & Info" heading and under it is "Articles". You might want to do some reading. Yesterdays Tractors has a copy of Don Stewarts excellent 8N M/S Carb rebuild page..... .....Dell
'52 8N (MD)
06-18-2003 17:26:07
 Re: Re: carb repair kit in reply to uh . . . Dell (WA), 06-18-2003 08:45:57
The article by Don Stewart was helpful but the NH carb rebuild kit has different parts. There are three jets in the TX241 on my 8N and the kit came with five to accomodate the various models in service (A/B/C). I ended up measuring the new jets with different gauges of guitar strings to make sure I was using the correct jets.
As it turns out I had to run with the choke (out about 1/3) because there was air getting in past the throttle shaft and also at the manifold gasket. Fortunately, the NH repair kit had the seals for both the choke and throttle shafts.
