Dressing the axel shaft!
Rob
06-20-2003 11:52:47
This is taking forever because this axel is really big and really hard!
Any body have a new, high-tech, easy, and fast way short of taking it into a shop to be turned?
I've burned 3+ hours and 3+ yards of emory cloth getting the seal score off these shafts.
Boring!
Hobo,NC
06-20-2003 16:48:35
 Re: Dressing the axel shaft! in reply to Rob, 06-20-2003 11:52:47
what I try to do when I have that problem is to reposition the seal. I take a hole saw about the O.D. of the seal then trim the I.D. to the seal and cut a ot. oil can, Its about .035 or a five gal. bucket (.090) and install the shim before the seal and then drive in the seal. works out good most of the time. The input shaft on my N was worn were the seal runs and that is how I repaired it. On some truck seals I remove the spring in the seal and cut some out of it and reinstall. always do it on GM 1/2 ton truck rear axle seals.
Rob
06-20-2003 17:55:48
 Re: Re: Dressing the axel shaft! in reply to Hobo,NC, 06-20-2003 16:48:35
Shimming that seal to move it is pretty slick, thanks. That's probably what I should do. I should have done that this morning.
On that shorten the spring thing, does that make the seal ID tighter? It just a tighter seal in the same grove? Is that the idea or what?
This grove isn't very deep. It's almost gone but dang it takes a LOT of doing. It's not like I'm having to remove so much mat'l from the shaft, the axel is just such really hard metal. It doesn't come off easy.
Hobo,NC
06-21-2003 04:13:58
 Re: Re: Re: Dressing the axel shaft! in reply to Rob, 06-20-2003 17:55:48
Thats the idea. First try it on the old seal spring.
markct
06-20-2003 12:28:11
can ya put a speedy sleeve on it, they are available from napa or most industrial supply places. they are basicly a thin stainless sleeve that ya press over the original shaft and give the seal a smooth place to ride, if your shaft is so scored that a couple hours of emery wouldnt clean it up then i think a speedy sleeve is the way to go. i have used them on the wheel seals of heavy construction equipment and they work great
Rob
06-20-2003 12:56:06
 Re: Re: Dressing the axel shaft! in reply to markct, 06-20-2003 12:28:11
This score wasn't any worse then usual. Most of it came out fine but the last little bit, a few pits, and it's slow....real hard metal and slow.
If it was any bigger axel shaft I wouldn't even bother. I'd get one of those sleeves you are talking about.
I probably should have split the emory cloth so I wouldn't have to sand such a wide area. An inch wide isn't much on cold rolled or even hot rolled but this hard axel....boy it takes a lot of elbow grease.
Pressed on? End up waiting on a shop anyway.
