Bush hog rock dust suppression
Rob
07-04-2003 11:25:33
third party image
I wanted a piece of rubber belt across the front of my rotary mower because when I scalp the crown of my bar ditches that hog throws up rocks and gravel. The local F/NH dealer sells the Bush Hog brand mowers with a rubber curtain across the front.
Asked the dealer if I could order those parts to retrofit my hog with a curtain and he came up with a piece of baler belt. Just gave it to me and said it will help control the dust too.
Well he was sure right. I've always accepted getting dusty running that hog but now I know I didn't have too. That rubber curtain just stops the dust, period. I notice the difference in the first 10 feet.
Knowing what I do now I would have put that belt on there a long time ago just to control the dust.
I welded slotted angle across the front top and bolted the belt to the angle. If I had to do it again I would use the vertical slots in the angle for the belt. I might have gone with a bigger angle so I was sure to clear the front deck support. Bolt clearance with a deck support was a problem.
The blade is trimming the lower center of the curtain. Shouldn't be a problem 'cept it's looking ragged now.
