Thanks All
Hydraulics Now on Viagra
'52 8N (MD)
07-16-2003 11:24:31
It almost seemed to easy to be true. Changed the 8N-638 hydraulic pressure relief valve ($6.75 used from Wengers) along with $60 (5 gal) in 134 Hyd Oil and voila - a lift that stays up with 275 lbs on it overnight and doesn't knock anymore. I wish I had a better (read cheaper) place to get the '134' but I can't complain; it could've been over $300 to recondition the lift arm and pump assemblies. My thanks to everyone who keeps answering the same questions every week to the benefit of N'ers everywhere.
As usual I have to end the post with a question. The used pressure relief valve I put in my '52 8N looked dramatically different than the one that came out of it, which is the one pictured in the MPC/FO-4. The head is hex shaped with a flush fitting slotted screw in the end of it. The unit was slightly longer and the oil passage holes in different places. Was this off of a 1953+ tractor? Thanks Again, wc
dachshund
07-17-2003 02:17:54
 Re: Thanks All - Hydraulics Now on Viagra in reply to '52 8N (MD), 07-16-2003 11:24:31
If you gat a Walmart Super Center - $23.88 for oil
Sam's Club - $18. How hard is it to change the valve on a 49 - I've been told by several that it may be the reason my lift arms won't work.
'52 8N (MD)
07-17-2003 05:44:50
 Re: Re: Thanks All - Hydraulics Now on Viagra in reply to dachshund, 07-17-2003 02:17:54
Page 15 of the Master Parts Catalog shows the same set-up for 1948-1952 although the 8N638 press. relief/control valve normally is not associated with the lift arms not raising at all. For that I'd look to the hyd. piston, etc.
Steve IA
07-16-2003 14:25:57
Even rural WallyWorlds sell 134 oil. Under $30.
Steve 8N 169302
will
07-16-2003 14:21:13
Wow! 60 bones? 29.95 at Autozone.Hope I have luck like you had. what is wengers?
'52 8N (MD)
07-17-2003 04:48:21
 Re: Re: Thanks All - Hydraulics Now on Viagra in reply to will, 07-16-2003 14:21:13
An outfit outside of Lancaster PA. They have a webstore.
John Webb
07-16-2003 12:34:13
Man the NH dealer only charged me $36 and I thought that was a little high,who's getting $60 if you don't mind me asking?
'52 8N (MD)
07-17-2003 04:47:18
 Re: Re: Thanks All - Hydraulics Now on Viagra in reply to John Webb, 07-16-2003 12:34:13
My local NH dealer, Walter Coale in Churchville MD. $30+ for 2.5 gal.
souNdguy
07-16-2003 11:36:32
Yikes .. 60 bucks for the oil...
Don't you have a napa / car quest / farm supply store near you? Most of their universal transdraulic oils meet the 134d specs... I paid about 25 bucks for a 5 gallon pail at TSC a couple months ago..
Glad to hear it is working good.
Soundguy
