Leveler box rebuild
Rob 9N
07-27-2003 07:08:46
Hi All, Any body out there do a rebuild on a leveler box, or am I wasting time thinking about it?
david - OR
07-27-2003 08:52:10
 Re: Leveler box rebuild in reply to Rob 9N, 07-27-2003 07:08:46
It's easy. You can buy the shaft, gear, and bearing individually and replace only what you need. Getting the rivet out of the gear without buggering the gear up too badly is the only tricky part. Also, if the shaft is bent, you have to saw it off to get it out of the housing. I replaced the rivet with a roll pin -- I will probably scare up a proper rivet "someday".
raytasch
07-27-2003 08:48:28
Tear it apart and see what is wrong with it. Parts are available.
ray
Hi,Rob...John,PA
07-27-2003 07:19:29
I don't think that think'n 'bout keeping your 9N as original as possible, is a waste of time.
Although I never rebuilt the levelerb box on my 9N, you might try to figger out what is wrong with the one you have.
Just a thought. Hope it helps.
Rob 9N
07-27-2003 10:22:58
 Re: Re: Leveler box rebuild in reply to Hi,Rob...John,PA, 07-27-2003 07:19:29
Cool, I'll break it down and see what it needs. Thanks again. Rob
Mike
07-27-2003 20:47:56
 Re: Re: Re: Leveler box rebuild in reply to Rob 9N, 07-27-2003 10:22:58
Rob,
Send me an e-mail, I might be able to help.
Mike
