Proof meter light question
'Ole Henry' (Va
08-08-2003 06:02:49
I have a replacement proof-meter with light that apparently has no bulb or is shot (no light when attaching a wire from battery), how do I remove the housing to access the bulb?
Thanks in advance.....John A
'Ole Henry' (Va)
08-08-2003 12:20:43
 Re: Proof meter light question in reply to 'Ole Henry' (Va), 08-08-2003 06:02:49
Thanks folks, the meter is in the dash just didn't know what that little thing-a-majiggy was until a couple of posts ago.
Ain't this board great.....John A
D. R. White MN
08-08-2003 10:55:04
All you need to do is wiggle the little light socket back and forth and it will come off but before you do that if your tractor is possitve gound you need to run the wire from the negative not the possitve side of the battery to the light. Hope this helps. Dave.
Jim.UT
08-08-2003 11:47:42
 Re: Re: Proof meter light question in reply to D. R. White MN, 08-08-2003 10:55:04
Oh yeah, that brings up another point. If you're just holding your new proofmeter in your hand and touching the wire to the battery, you're not gonna get any light because you do not have it grounded. You've gotta complete the circuit before anything happens. When it's installed the grounding happens by the proofmeter housing contacting the surrounding metal dash.
Jim.UT
08-08-2003 09:50:43
It's been 2 years since I did that and my memory is dim. I'm sure the light socket came out of the proofmeter from the back....no need to break into the proofmeter housing. However, I seem to remember doing it wrong the first time and having to buy a replacement socket after breaking it. I'll try to look at it again this weekend to see if my memory comes back.
