Dell, (and others) - - - Bees wax question
'Ole Henry' (Va
08-16-2003 19:11:34
Reading a few post down about using bees wax (I think) to free frozen bolts. This is sometinig new to me, gimme the scoop.
John A
'Ole Henry' (Va)
08-17-2003 11:12:28
 Re: Dell, (and others) - - - Bees wax question in reply to 'Ole Henry' (Va), 08-16-2003 19:11:34
Learned something new - proves I still ain't too old, thanks...John A
Dell (WA)
08-16-2003 20:06:09
John..... ...use real beeswax from saddle leather harness shop or wifes sewing notions store. Canning wax don't do it.
Heat your stubborn bolt/nut, then melt the beeswax against your hot nuts. Capillary action will suck the hot melted wax down into the joint. Beeswax doesn't evaporate like some of the other panther p*ss does. Besides busting the rust, the wax acts as lubricant when removing..... ...Dell
ED-IL
08-16-2003 20:06:07
I used it to loosen a stud from the front wheel hub on my 2N. I heated the stud with a propane torch, then rubbed a beeswax candle on it. After repeating this 4 times, I was able to drive out the stud.
