Order Ford 9N Parts Online
shifter boot on 9n
rob
09-07-2003 20:29:08
does anyone know of a trick to get the TIGHT rubber boot on the shifter joint on the trans. having a rough time with this one
rob
09-08-2003 07:45:57
 Re: shifter boot on 9n in reply to rob, 09-07-2003 20:29:08
im going to go try it now...thanks for the help...i just had so much water in the oil it looked like butterscotch...
souNdguy
09-08-2003 07:33:59
That's a funny one isn't it. Really brings meaning to the term 'interference fit'. I guess the engineers at the ford plant figured they would have fun with everybody watching them trying to install them... I figure we wouldn't have so many N's with water in the hyd sump/tranny/rear end, if ford wad an easier to install boot.. oh well...
On both the NAA and 8n I replaced the boots. I used a piece of heavy gauge wire rolled back on itself to make a smooth 'tong', as a 3rd finger.. etc.. and used the method that someone else mentioned.. roll the boot back over itself, etc. Had to hold your mouth just right.. but it went on.
A word of advice... clean the grove that the bottom of the boot rides in.. makes life easier.
Soundguy
Pete--NY
09-08-2003 03:43:15
Rob, I just put one on. In addition to the soap, I rolled the boot up over itself (kind of inside out) and then unrolled it at the bottom. Worked great. Pete--NY
Fast Ed Ohio
09-07-2003 23:19:52
Soak in hot water, use soap .( im talking about the boot) not you .
