Order Ford 9N Parts Online
POINTS GAP ON 41 9N
BOB G (TEXAS)
10-25-2003 16:59:31
I can't seem to get to points to open wide enough to get the correct gap. Any suggestions? Thanks.
Scott
10-26-2003 05:12:42
 Re: POINTS GAP ON 41 9N in reply to BOB G (TEXAS), 10-25-2003 16:59:31
If they were not made in US or Mexico most will not open enough, you may need to shop for another set and check the label.
Fast Ed Ohio
10-25-2003 22:55:46
More info would be helpfull, did you just put in new points? are you trying to adjust old points ? Are you trying to set them at 0.15 ? Is the dist. in your hand so you can check it out ? You do have a 6 volt front mount right ?
BOB G (TEXAS)
10-26-2003 14:42:21
 Re: Re: POINTS GAP ON 41 9N in reply to Fast Ed Ohio, 10-25-2003 22:55:46
New points, but it didn't run good before I put them in. Trying to set at .015. Distributor is front mount and it is currently on the tractor. It is a 12 volt system. Thanks.
