Order Ford 9N Parts Online
9N Brake Problems
Rob
11-12-2003 08:06:31
I have read many of great posts about the 9N brake and seal installation, but before I dive into that project I need to be sure that is what I have to do. My right brake peddle only works if a 400lb man jumped on it and the left brake does not move at all. I just did a major overall on the electronics, clutch, carb and flywheel ring because the tractor had been sitting for about 5 years. Also, there does not seem to be any leaks on the axle. Please help.....
Ron from IL
11-12-2003 08:30:41
 Re: 9N Brake Problems in reply to Rob, 11-12-2003 08:06:31
Rob, Do what I did: buy the video (listed at the left of the screen) on brake repair for the 9/2/8N tractors. It's $24 and is well worth the cost. The only thing they don't discuss is breaking the brake shafts loose. Use a penetrant (PB, Kroil, etc.) and heat. You may have to use an arbor press in the worst case.
Good luck!
Ron
p.s.-Check the archives for more info.
Rob
11-12-2003 12:33:59
 Re: Re: 9N Brake Problems in reply to Ron from IL, 11-12-2003 08:30:41
thanks Ron, I will take your advice if required. Based on the symtoms, is a brake job inevitable or could something just be stuck???
Ron from IL
11-12-2003 12:45:33
 Re: Re: Re: 9N Brake Problems in reply to Rob, 11-12-2003 12:33:59
Rob,
It sounds like your shaft bushing is seized (like mine). Try the penetrant--you just might luck out and not have to disassemble the whole thing!
Good Luck!
Ron
Rob
11-14-2003 14:51:53
 Re: Re: Re: Re: 9N Brake Problems in reply to Ron from IL, 11-12-2003 12:45:33
thanks Ron, I'll give her a shot
