Order Ford 9N Parts Online
My leg is gettin' tired, need a foot rest for a 9N
Rob in Virginia
11-18-2003 12:15:25
Anybody out there know where I can get a couple of foot rests for a 41 9N. I am in desperate need of them or at least a right side peg.
appreciate it.
Rob in Virginia
11-19-2003 04:38:05
 Re: My leg is gettin' tired, need a foot rest for in reply to Rob in Virginia, 11-18-2003 12:15:25
Thanks for all your help, I have a couple of leads now and they fall thru, then I will go ahead and have them fabricated'
thanks
Rob in Virginia
11-19-2003 04:36:52
Thanks for all your help, I have a couple of leads now and if they fall through, I will go about trying to have some fabricated.
rob
steve Mi
11-19-2003 02:02:58
heres the plans to build your own
Scott
11-18-2003 16:14:08
third party image
Rob,
you CAN use footrests off a 8N with a little modification. I removed the red rear "L" shaped mount and made 2 new ones with the horizontal mounting holes moved out about 3/4 inch. This will give you clearance for the 9N clutch rod. You might need to remove a little of the inside "lip" on the footrest depending on how tight you run your clutch.
I've never tried them without the foot pegs, but I'd bet it would work. I just like to have something to hook by boot heel on.
8N boards are available on Ebay every now and then.
My nickels worth,
Scott
Dan in Myersville
11-18-2003 12:52:15
Got a pair from tOTG - real nice and a perfect fit. Uses the radius rod cap bolts up front so you don't have to have the pegs. I tack welded some 1/2" X 1/8" flats to the edges of the tread plate for additional support.
Rob in Virginia
11-18-2003 13:21:27
 Re: Re: My leg is gettin' tired, need a foot rest in reply to Dan in Myersville, 11-18-2003 12:52:15
Pardon my ignorance, but where is tOTG and how do I get a hold of them thanks
Danny in CO
11-18-2003 14:17:02
 Re: Re: Re: My leg is gettin' tired, need a foot r in reply to Rob in Virginia, 11-18-2003 13:21:27
Rob,
tOTG is John Bowers (alias the Old Tractor Guy). He is in Littleton, CO. His Web Site might help.
Good Luck,
Danny
souNdguy
11-18-2003 12:56:12
Nice.. don't even need the pegs..
Soundguy
Dell (WA)
11-18-2003 12:42:45
Rob..... ...fellow by name of Rod advertizes in the N-Newsletter that he sells primed 9N & 2N running boards made in USA. $50. 651-464-4628 (MN) fltractor@peoplepc.com. I hate re-inventing the wheel ...er... running board when the price seems reasonable..... ....Dell
souNdguy
11-18-2003 12:47:05
 Re: Re: My leg is gettin' tired, need a foot rest in reply to Dell (WA), 11-18-2003 12:42:45
Yep.. that's one of those buy and install things.. why make up a welding jig. etc.
i also noticed that there are now 2 fixes for NAA tool boxes.. you can either buy the whole running board, or just the box-repair insert. .. Think I also saw that in the N-newsletter..
Though I fixed mine with sheet mental.. I might have to pony up for a good looking copy like that..
Soundguy
souNdguy
11-18-2003 12:32:22
Most of the aftermarket foot rests require the pegs.. so better take care of that too.
The smiths site has some from time to time.. though i didn't see any today. might try denniscarpenter, or even don barkley.
Soundguy
Rob in Virginia
11-18-2003 12:40:35
 Re: Re: My leg is gettin' tired, need a foot rest in reply to souNdguy, 11-18-2003 12:32:22
thanks, do you have their websits or phone numbers?
souNdguy
11-18-2003 12:42:54
 Re: Re: Re: My leg is gettin' tired, need a foot r in reply to Rob in Virginia, 11-18-2003 12:40:35
Also.. you might check the parts section here on this forumn.. but I don't think they carry the 9n/2n plates that most 'retrofit' for use.. etc.
Email me..
Soundguy
