Radiator on e-bay
Rob N VA
11-24-2003 04:49:22
Anybody seen these? I was just curious about the quality. TSC sells a 200 dollar radiator that I have heard is pretty good, but for about 75 dollars more I could have my original recored. Anyway, like I said, I was just curious if anyone had heard about the quality of these radiators. Thanks---Rob
jim
11-24-2003 19:42:58
 Re: Radiator on e-bay in reply to Rob N VA, 11-24-2003 04:49:22
I believe the radiator is made in Turkey.
I bought one for my Jubilee and it was fine.
Jim
gspig
11-24-2003 17:22:14
I just bought one this fall from this person. It is a very solid radiator and does come with a new cap. I have already managed to twist the cover off the cap. The drain cock is not in the same position as the original, but does not seem to create a problem. I did have to get 2 bolts to mount the radiator. I slid the bolt heads into the mounting ears under the radiator and that seemed to work. I have a shroud on my radiator and had to grind for clearance for the overflow tube.
John Norquist
11-24-2003 16:14:26
I recently purchased the same radiator. It is very well made. I have bought several things from this person without any problems. I highly recommend it. Mine even came with a new radiator cap. One minor change I made to my radiator is to solder on a longer copper tube for the overflow. I don't have a digital camera to send you a picture. If you have any more questions, email me directly.
John
Jeb2N
11-24-2003 15:10:36
You can check the archives for the plethora of posts on this very subject. You can actually find these radiator for as low as $145. Most people have had problems with the replacement radiators (leaking right out of the box, didn't quite fit right, etc), few have had good ones, and everybody i've heard that went the route of the re-core (myself included) has been very satisfied and had zero problems. I (biased opinion) would, and have, opted for a re-core because i know it will fit, and i can take it back and have them fix it for free if it leaks. Just my $0.02
Rob N VA - DUH!!!
11-24-2003 04:50:51
I guess the website would help you guys to know what I am talking about. SORRY!!!----Rob
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2574867320&category=26193
