screw at the end of crank...help
rob
01-06-2004 08:57:47
holding on the pulley at the end of the crank is a LARGE flathead screw...how do you get this off w/o completely destroying it? ive tried heat and made a large flat blade out of a wood chisel all to no avail...im ready to drill it out...anyone have any suggestions? as an off topic, does anyone know of an aftermarket cam (more power) manufacturer and how much you can mill off the head with out having valve to head contact
Dell (WA)
01-06-2004 09:37:31
 Re: screw at the end of crank...help in reply to rob, 01-06-2004 08:57:47
Rob..... ...you distroy the cheap sunnagun.
TIP: stuff some soft 1/4" clothesline rope down enny sparkie hole to stop the crankshaft from turning so you can remove the 150 ft/lb torqued crankshaft bolt. Usually, the crankshaft pulley bolt is a "crownhead" crank'em bolt p/n 2N-6319-A1, 5/8-18 X 1-5/16 hex ratchet; and is tapered on backside to center the pulley.
Power is governed by rpms or displacement or compression. The 26 hp N-Engine is governed at 2200 rpms, max power is 1800 rpms. Hot-rod cams increase power by improving breathing at high rpms, not an N-Engine specality. The displacement can be increased about 4% by throwing out the sleeves and using slightly larger Merc piston and ruining the block for future rebuilds. You can mill your flathead MAX 0.010 before valves start beating the cylinderhead.
OR..... you could SUPERCHARGE IT!!! Get a Chevy bigblock SMOGPUMP for $20 from junkyard and a M/S carb for OHV NAA Jubilee (so the carb mouth lines up with smogpump output). Figger out some bracketts and belts and POWER AWAY. (TIP: read up on supercharging in hot-rod books)..... ..Dell
John IA
01-06-2004 20:00:49
 Re: Re: screw at the end of crank...help in reply to Dell (WA), 01-06-2004 09:37:31
Rob,try Dell's trick with the rope in the cylinder. Use the biggest screw driver you can, or a hand impact with screw driver bit. The kind you hit with a hammer. The only other way other than drilling is to weld a small nut to the center of the screw to turn it with a wrench. Like dell said the N had a hex head bolt with the crank deally on it, unless your tractor had a front mount loader on it where that flat headed screw is used under the pump drive. John
